This guy's videos on "where does the tone come from" regarding guitars, cabs etc have been highly entertaining and informative. Now i just saw a link to this (haven't had a chance to watch it through yet), but it sounds promising..(?)
I'm not sure I agree, but it also depends on what you're using it for I guess, and of course a lot of those mics' quality depends on who made it. I think the ones with the decent bigger capsules aren't too bad, but then you get the ones with like a 6 or 8mm capsule in a 16-20mm wide plastic ring that are no good, my experiences have always been with the latter ones. I definitely feel like you can cut some great tracks some cheap mics, as long as you don't mind the character of them. My NW-700 had one of the tiny capsules and a super resonant body, it sounded pretty tinny to me, but when I got it that's all I could afford. I tried a couple similar mics at other points too, all of which were bad enough I sent them back to Amazon.Stock BM800 is perfectly useable mic
I made kind of a extreme example to point out how a less obvious parameters get omitted in typical shootout. But even a bm800 can sound quite nice on a right source with some eq.I'm not sure I agree, but it also depends on what you're using it for I guess, and of course a lot of those mics' quality depends on who made it. I think the ones with the decent bigger capsules aren't too bad, but then you get the ones with like a 6 or 8mm capsule in a 16-20mm wide plastic ring that are no good, my experiences have always been with the latter ones. I definitely feel like you can cut some great tracks some cheap mics, as long as you don't mind the character of them.
Of course I'm quite partial to my Oktavas and my CAD M179s and AT4050 even though plenty of people would say those aren't good enough to be "professional" despite the amount of completed projects using the AT and Oktava mics.
This always seems to be the case when comparing them. Somebody compares them in close proximity in cardioid and they do sound fairly similar, but it's still a K67 and it's going to have similar rejection and similar changes in frequency response as any other one because where the wires are placed means nothing. I wish AKG made capsules for the DIY crowd, I'd absolutely rather have a TLII capsule over an RK-12 (of course I'd prefer an older CK12 style capsule tuned the way I want, but that's a lot more specialized).No, for the 100th time, the MP capsule is not like the one found in 251, but in the end you can see he is satisfied with how "similar" they sound.
Yeah I've heard some really good processed recordings from them. I actually recommend them for content creation if you can get a good one. No sense in wasting $1000 on a TLM103 if you're just doing a small podcast. Same way I'd recommend a good cheap hypercardioid and cardioid if you're on camera and need a cheap mic you can boom. No point in springing for a Schoeps or DPA if an MK-012 or AKG Blueline will work for you and you're just doing YouTube or something. And they can definitely sound good on some music if you're an independent artist or making demos. Hell, I'd probably prefer one of the good BM-800s on a cabinet over an SM57, but I reaaaally hate the 57.I made kind of a extreme example to point out how a less obvious parameters get omitted in typical shootout. But even a bm800 can sound quite nice on a right source with some eq.
Yeah, his naive development of testing methods has resulted in a pretty misleading video.He asks a lot of interesting questions, but his testing methodology doesn’t make much sense to me. By cutting between 1 second clips of an already-recorded distorted guitar that’s being reproduced by a close-miked speaker, you’re only going to notice changes that affect the frequency balance of the signal in a major way. A lot of the important details that “make the mic” (distortion profile, transient response, off-axis response) get lost. Also, these things matter more when the sound is being recorded for the first time, vs making a recording of a recording. If I didn’t know better, I would’ve come away from the video thinking many of the parameters he tested don’t make a noticeable difference, which I have not found to be the case.
That's one of the reasons I don't find Audio Test Kitchen particularly reliable. I'm pretty sure they do this same kind of testing.He asks a lot of interesting questions, but his testing methodology doesn’t make much sense to me. By cutting between 1 second clips of an already-recorded distorted guitar that’s being reproduced by a close-miked speaker, you’re only going to notice changes that affect the frequency balance of the signal in a major way. A lot of the important details that “make the mic” (distortion profile, transient response, off-axis response) get lost. Also, these things matter more when the sound is being recorded for the first time, vs making a recording of a recording. If I didn’t know better, I would’ve come away from the video thinking many of the parameters he tested don’t make a noticeable difference, which I have not found to be the case.
The tone of a mic comes from several things, the diaphragm, and the material that it is made from, which effects where it resonates, how it's damped, the type of mic, if it's a charged plate (condenser) or dynamic (like a speaker with a voice coil), the amplifier if it has one (condensers have at least a FET, maybe more, or a tube or two) the output transformer, if it has one, and what the core is made from, steel, nickel or a blend, the number of windings, etc, then of course how it marries with the input stage of the mic pre.
So the answer is "how long is a piece of string?"
Thanks for letting us know.This guy's videos on "where does the tone come from" regarding guitars, cabs etc have been highly entertaining and informative. Now i just saw a link to this (haven't had a chance to watch it through yet), but it sounds promising..(?)
There are too many issues in the video to address.
I’m still considering what to do with the one capsule from Tim I still haven’t done anything with yet. I know I want to put it in a solid-state. One simple thing I’m considering is grabbing a used 414 XLII and putting it in there. Of course I’m already regularly using stock XLIIs in omni on a regular-basis with great success. I’ve surprisingly yet to hear anyone switch-out an XLII or TLII capsule to hear if it was a worthwhile effort yet.I wish AKG made capsules for the DIY crowd, I'd absolutely rather have a TLII capsule over an RK-12 (of course I'd prefer an older CK12 style capsule tuned the way I want, but that's a lot more specialized).
I wish AKG made capsules for the DIY crowd...
