GeorgeToledo
- Joined
- Mar 3, 2015
- Messages
- 384
This is simply not true, you are breaking laws of physics here. Can you provide any documentation to substantiate this? Or measurement? If two microphones have same exact frequency response, and their upper and lower limit of FR extends to the same point they will have exactly same TR. It seems you are mixing up TR and IR.
However if you have two mics that have same exact FR say 20-20.000hz but FR starts to differ above 20.000hz you do indeed get different TR.
I don't get why make things so complicated. Transient response is determined by the frequency response extension, or bandwidth. You can not limit FR and have good TR, same as you can't have wide FR and claim TR is bad just because the mic sounds dark.
I am of course talking about operation in linear region, and presuming microphones are not clipping.
Assuming that which is defined to not work linearly, does work linearly, is probably not a good foundation.
Varying harmonic distortion with level isn’t necessarily recognized as clipping, but is enough to make the situation more complex.
This is the same reason the amp modeling market has developed more complex techniques than using a single IR.
A mic would have to have impulse response taken at various levels, on axis, off axis, etc, and then have some interpolation scheme that would at best be an approximation, in order to have some sort of *rough* mathematical model.
Textbook examples of minimum phase devices vs non, immediately reveal several common sub-systems in microphones to not be minimum phase by definition.
