Wonder whats next?? SSL 9K- 500 Series Preamp.
Do someone tested the Carlos Lima pdf ?
3nity : did you do this V2 finally?Maybe something summing up the way to get it working?
Many thanks...I'll stuck to Carlos PDF , but I'd like to be sure before powering it up!
EDIT : do someone have a # for the switches?
Actually V2 layout is ready..but prototype is not.
I havent had the bucks for it...
I'm pretty sure it will work this time but we have to test it...
Thanks.
Hi ,
here's time for my stupid questions :
R1=51R ?
R84=6K8 where on the pcb?
R59=?
R60=?
R61=?
R62=?
R63=?
R64=?
R65=?
C1=?
C45=100nF : correct ?
C49=?
C50=?
C83 : where on the pcb ?
D1,D2,D3 : what should I do?Omit them and replace with straps?Just put them in place?Is orientation good?
Is there a suitable sub for Thata1646 without any mods (just for testing without blowing an expensive AOP)
EDIT : what about the switches?3nity have you got a suitable # ??
By advance , many thanks to everyone who will help!
3nity ,
I think I should share this (if not already covered my someone else) :
the gold connector (in the 9K5s I have) mesures approx 60,25mm (large), in my Edac connector the loss is high.If I do not care to plug it centered, Edac and gold plated pins do not exactly face themselves/eachother.(Causing pins gap)
After mesuring some other one gold plated connectors , it seems 62mm is the minimum ; EDAC mesures 63,75mm inside ...
My x cents.
Hey Red.
Read your pm.
I did my best trying to prototyping this beast.
I'm not sure to understand your measures if you care to share it would be really helpful.
Guys i promise to all you that the latest proto is ready, well now to check the finger connectors.
Its just a matter of having some free bucks and do a pcb and aproval.
Please show some patience..
Thanks Rednoise your help is apreciated.
Jorge A.
Although this topic is old. But even so.
I would like to build one SSL 9K-500 series.
Can I get a file somewhere PDF SSL 9K-500 series of printed circuit board (PCB).
I'll be grateful to you.
Sincerely.
Sincerely.
Check the links and documents here.
https://pcbgrinder.com/index.php?route=product/product&path=59_80&product_id=63
Gustav
