[quote author="StephenGiles"]This is one of the most fascinating threads I have ever followed, although I need to sit down for a couple of hours in peace to understand it. Which is the latest schematic and is it still likely to be improved.
Just a thought, could the high pass alone be used to clean up a hissy cassette recording?[/quote]
You could rearrange the pieces to deliver a HF cut dynamically when you determine that the spectral signature is predominantly noise floor or just when HF is below some threshold.
You could make the HF attenuation follow a slope similar to a downward expander, so it doesn't sound choppy.
IMO this wouldn't be as effective as a dynamic sliding LPF as promoted by Nat Semi in that old DNR (?) chip, or the combination of sliding LPF with downward expansion which could be quite effective. The SENR (single ended NR) I did used two VCAs one for the variable LP and another for the downward expansion, but that's a little more complicated circuit.
Getting back to modifying this for SENR, the opamp comparator that defeats the de-essing needs to be retargeted to just stop the de-essing gain manipulation, while another opamp LOG computation is performed, with perhaps another threshold (and slope?) adjustment, determines when to start scraping off highs and an appropriate ratio. Note: In my experience even 1:2 is a pretty severe slope so ratio may want to be modest for best sounding result.
