Arrived. Initial impressions are pretty positive. Body tube is a good weight and thickness, not overly heavy but not thin or ringy. Threads are all solid, some are a bit burred but not to the extent that things hang when threading them together. The swivel mount joint is a good tension out of the box but is slotted to allow tightening / loosening if needed.
As expected the "switch" is nothing more than a plastic ring with a cardioid sticker.
They did include a spring for the cable outlet, which I didn't expect so that was good. I thought at best there would be a rubber boot, spring is a nice surprise.
I don't love how the female side of the connector is held in place on the swivel, which is with set screws. The insert itself is threaded, but the swivel does not have any threading so set screw it is.
Here's some pictures:
