Many thanks! That is great!
[quote author="manarm"]Hi
PFL detect is done by IC10 B (TL 072) on the Right Hand of the master module.
Check if Talk Back works : it uses the other opamp of IC 10.
Then IC10 B drives TR13 and TR14 who drive the fets that flip/flop the mix/PFL signal in control room. I hope it's clear to you... :?: All this is powered by R253/R254 (10 ohm)[/quote]
Yes, it´s clear to me. I don´t know if it will be clear to the guy who has been "servicing" the desk: He cleaned the desk, and changed some inserts, and when I got the desk back, the PFL was gone... :evil: Oh, and I had to realize that the hard way when I wanted to start a quick headphone-linecheck with a live-band - aaaarg! That´s what I call "service" :green: I fear I have to do it myself if I want to have my desk back in working order... I only gave it away because I had no time left...
Give me your email, if you want, and I'll try to send you a scan of the schematics.
In another way, your problem can be caused by the bus : cut wire in the loom or shorted to ground...[/quote]
Thank you very much! :sam:
Toff
