Hi everyone!
I've got some rack cases and front panels available for sale, these should make a lot of projects a lot less painful as most of the metalwork's done for you. You can buy the cases or the front panels separately.
The cases have:
- Holes for an EMI filtered power connector on the rear panel
- Four holes for XLR connectors on the rear panel
The cases are approximately 44 cm wide and 28 cm deep, the internal height is about 39 mm. The cases have 1.5 mm thick lids so that contersunk screws can be used, keeping the outside of the enclosure clean. A 1U case + front panel weighs less than 2kg including packaging so it can be posted quite cheaply.
Here's what I currently have:
EZ1073 case for Colin's (Slenderchap) project... 99 EUR including Worldwide postage! - Neve type blue/grey colour
EZ1084 panel... 32 EUR + postage
Full case including worldwide postage = 95 EUR
2U EZ1084 panel - brushed Aluminium with laser engraving... 35 EUR + postage
Full case including worldwide postage = 122 EUR
EZ1290 panel for madriaanse's project... 32 EUR + postage - Neve type blue/grey colour
The panel's designed for the JLM GoBetween.
2x 1176 panel... 35 EUR + postage
1U 760 panel... 42 EUR+ postage
Full case including worldwide postage = 102 EUR
2U 760 panel... 47 EUR+ postage
Full case including worldwide postage = 144 EUR
2U G9 panel... 35 EUR + postage
2U Pultec panel for NRG Frank's project... 35 EUR + postage
1290 panel...32 EUR + postage - Neve type blue/grey colour
1272 panel...32 EUR + postage - Neve type blue/grey colour
GSSL panel... 32 EUR + postage - blue/grey colour.
W492 panels - silver brushed Aluminium + Al mounting panel... 2x W492 plates + 2x rear mounting plates... 32 EUR + postage
____________________________
New additions:
2U Stereo PQ1549 EQ panel - brushed Aluminium with laser engraving 35 EUR + postage
Don't have the PCB? Ask Lukas! http://groupdiy.com/index.php?topic=62360.0
(the artwork's here: http://www.gyraf.dk/gy_pd/calreq/calreq.pdf)
1U XS902 De-esser panel - brushed Aluminium with laser engraving 32 EUR + postage
1U Nite EQ panel + sub panel - brushed Aluminium with laser engraving 40 EUR + postage
Full case including worldwide postage = 103 EUR
500 series Audiox196EQ panel + L-bracket 29 EUR + postage
1U CLX-VU panel - brushed Aluminium with laser engraving 32 EUR + postage
2U M/S VECA panel - brushed Aluminium with laser engraving 35 EUR + postage
1U Hand Of Light panel - brushed Aluminium with laser engraving 32 EUR + postage
1U Symmetrical FET panel - brushed Aluminium with laser engraving 32 EUR + postage
Front panel postage costs:
- 1x 1U panel = 7 EUR
- 2x 1U panels = 9 EUR
- up to six 1U panels = 14 EUR
Ordering:
You can send money through Paypal of by bank transfer, please email me at dan.ddt -at- email.cz first to confirm availability and the total amount.
If you want to be original with your front panel designs (and you should), you can also get your panels done here http://www.groupdiy.com/index.php?topic=27917.0 or here (scroll down a bit for English) http://www.nrgrecording.de/nrg/viewtopic.php?t=971. Or email me at dan.ddt -at- email.cz for a custom panel.
Dan
The cases have:
New additions:
Ordering:
Dan
