Hi guys,
The TG1, 4 Channel Pre and Sidechain GSSL panels are now available, I've added them to the first post with the quantities. I also have some non-sidechain GSSL panels available for use with a proper Sifam PPM meter, a slightly unusual solution for the W492 project, see below...
The 4 Channel Pre panels are designed for JLM GoBetween switch spacing, which means that you'll also be able to rack four of your Baby Animals with them!
The oval holes are big enough to take a flat lever toggle switch, but this will be tricky as you'll need to slightly angle them when inserting them through the holes and tighten them afterwards.
Because of the complexity of the extra metalwork involved, the
price for one panel is 35 EUR. But they look damn cool (even if I do say so myself)
I've also got some W492 panels which I think will be a cool change from the standard panels: there's a bolt-on faceplate for one W492 channel, plus a sub-plate for holding the pots and switches for keeping the faceplate clean of the mounting nuts. The panels can either be used with an off-the shelf case if you drill all the holes in the existing front panel, or I can supply a powder coated 1U panel with all the necessary cutouts at extra cost if you don't want to do any drilling.
The panel is designed to accommodate
11mm diameter knobs, the pots and switches on the sub-panel are a very tight fit, you will pretty much need to pre-solder wires to the pots before you attach them to the panel, the photo shows a worst-case scenario of how things will look. You can use a 1 pole toggle switch, I used 2 pole ones as I had them lying around.
The cost of two W492 plates and two rear mounting plates is 25 EUR,
The cost of a pre-drilled 1U mounting panel is 7 EUR.
