zayance
4mm to 6mm Pot Shaft Adapter
« on: July 28, 2010, 04:01:58 PM »
Hi Guys, well, i tried to custom make some with some drop offs of tiny brass tubing, adding two layers of different diameter, doing a cut on the lenght so for the set screw to tighten both the tubes, but the result is not that good, the pot doesn't turn very nicely, so i was wondering if such thing exists? Adapters for 4mm to 6mm Pot Shaft??
Or maybe some better trick?
Thanks a lot
« Last Edit: July 28, 2010, 04:09:22 PM by zayance »
Re: 4mm to 6mm Pot Shaft Adapter
« Reply #1 on: July 28, 2010, 04:10:01 PM »
www.banzaimusic.com used to have them for their 4mm Piher pots.
zayance
« Reply #2 on: July 28, 2010, 04:32:49 PM »
Nice, it's for 6.3mm knobs tough but that's ok, Thanks emrr  :)
sahib
« Reply #3 on: July 28, 2010, 04:57:39 PM »
Best trick is to turn them properly on the lathe. Does not have to be brass, a tight fit acetal will also do. Unfortunately I am going away on Friday and I don't have time but otherwise I could make some for you.
zayance
« Reply #4 on: July 28, 2010, 05:30:04 PM »
No Problem, Thanks anyway for proposing, i'll stick with the Banzai solution, or change pots  :), i mean knobs  ::)
« Last Edit: July 28, 2010, 05:47:01 PM by zayance »
mad.ax
« Reply #5 on: July 29, 2010, 03:22:19 AM »
This should do the trick nicely... (and cheaper than Banzai)
http://www.selectronic.fr/article.asp?article_ref_entier=10.9176-20
Axel
zayance
« Reply #6 on: July 29, 2010, 03:51:09 AM »
Even better. Merci
Last post August 31, 2004, 06:18:37 AM
by jhaible
Last post December 16, 2008, 08:05:51 PM
by Rob Flinn
Last post June 15, 2010, 07:53:36 AM
by Sredna
Last post September 22, 2020, 09:19:55 AM
by acquisitions
