Hi Guys, well, i tried to custom make some with some drop offs of tiny brass tubing, adding two layers of different diameter, doing a cut on the lenght so for the set screw to tighten both the tubes, but the result is not that good, the pot doesn't turn very nicely, so i was wondering if such thing exists? Adapters for 4mm to 6mm Pot Shaft??
Or maybe some better trick?
Thanks a lot
Thanks a lot
