drask
The Rude Tube Build / Support Thread (MAJ + PSU)
« on: August 23, 2012, 03:00:12 PM »
Please, ask your question here.
Rude Tube PCB Order (Order close - New order if some people are interested in)
http://www.groupdiy.com/index.php?topic=47485.0
Schematics
http://www.mediafire.com/view/?xmn97j9c294912z
PSU Schematic
http://www.mediafire.com/view/?rrp998i8yg23d2l
Bom / Manual
http://www.mediafire.com/view/?s95xkmf1cw72o54
The original Bernbrue's prototype.
http://www.groupdiy.com/index.php?topic=45502.0
frontpanel fpd file zipped
http://twin-x.com/groupdiy/albums/userpics/Rude_Tube.zip
Sorry for the 1st post. I'll update when I'm back home.
« Last Edit: September 06, 2012, 01:48:39 PM by drask »
Re: The Rude Tube Build / Support Thread
« Reply #1 on: August 23, 2012, 04:16:40 PM »
several questions:
i see some resistors with strange value:
32k              i can do a serie with 2 resistor, or? a 33k is ok too? if i use another TrafoIN, still this value?
2k8              i can do a serie with 2 resistor, or? a 2k7 is ok too?
70k              i can do a serie with some resistor
50k              i can do a parallel with 2 resistor or i can use a 49k9
8k25 2w      can i use 8k2?
where u have find them?
in the Mainboard BOM i see R19 as Unknow value, on the schema i see R19 as a 4M7...is correct?
and still the PSU question about C11 (2200µF 25V), i haven't found a 35V version with a 5mm pitch. Only a 25V, but i think is not enough...
drask
« Reply #2 on: August 23, 2012, 04:31:59 PM »
several questions:
32K => You can use 33K (I use this in my prototype, work perfectly) or use two resistors in serie.
2K8 => Serie with two resistor
70K => you can. I try with 71K and work.
50K => I don't remember what I put here. Need to check. ButI think I use two resistor in parallel.
8K25 => yes you can use 8K2. There is not big change. I've tried.
I use serie or parallel resistance in my prototype. And I build a new with the PCB from the factory.
and I try to use close value. But I've don't test it for the moment. I'll do this this week end.
I keep you inform for value.
Yes, In this BOM I forgot to put the value of R19. When I write the BOM I've not yet the value.
No, R19 is not 4M7.
For C11. I'll check when I back in belgium. I can't tell you now, I'm in hollyday.. Sorry..
jandoste
« Reply #3 on: August 25, 2012, 12:19:40 PM »
Hey Drask,
Can I use 1uF 250V  instead of  1uF - 400v [ C5 PSU ] I already got it :) 250V
and 0,1uF 450V Ceramic Cap instead of C10 100nF [ C10 PSU ]
drask
« Reply #4 on: August 25, 2012, 12:58:53 PM »
Hey Drask,
For C10 450v is not necessary and Yes you can use Ceramic cap. I haven't try it.
For C5 It's not preferable to use 250v. I prefer that you use 400v. Voltage is more important, when the Mainboard are not connected and turns around 300v.
best,
Jerome
jandoste
« Reply #5 on: August 25, 2012, 01:51:01 PM »
Thanks Jerome!
Hey Drask,
best,
Jerome
drask
« Reply #6 on: August 25, 2012, 03:00:59 PM »
several questions:
No, R19 is not 4M7.
For C11, I use 2200uF - 25v and it's work perfectly. But if you want to be sure use 35v.
R19, the unknown value is 9,1K normally (I'm checking)
R17 50k, I use 51K in my unit.
bernbrue
« Reply #7 on: August 25, 2012, 03:15:07 PM »
Attention,
the numbering of components in the BOM is different from the numbering in the schematic. Since I haven´t got a pcb nor a schematic of the latest revision I can´t tell which one is right and which one is wrong. It might be better for Drask to clear this up.
regards
Bernd
drask
« Reply #8 on: August 25, 2012, 03:22:45 PM »
Attention,
regards
Bernd
Yes Bernd, I'm just back at home.
The schematics is now updated with the last revision.
best,
Jr
« Reply #9 on: August 25, 2012, 03:56:07 PM »
drask, do you have the schematic of the PSU, also?
drask
« Reply #10 on: August 25, 2012, 03:59:26 PM »
I'll post in few hours.
drask
« Reply #11 on: August 25, 2012, 04:17:06 PM »
PSU schematic disponible ;)
« Reply #12 on: August 25, 2012, 04:18:55 PM »
grat! thanks a lot!
« Reply #13 on: August 27, 2012, 05:56:54 AM »
C1 on the mainboard is 22pF. Can I use it Ceramic, Multilayer or Polystyrene?
drask
« Reply #14 on: August 27, 2012, 06:13:26 AM »
Yes you can, Ceramic it's okay. I use this in my proto.
RATMNL
« Reply #15 on: August 27, 2012, 03:53:24 PM »
I KNOW what I'm doing, which does not necessarily mean I UNDERSTAND what I'm doing. Subtle Differences.
drask
« Reply #16 on: August 27, 2012, 04:17:27 PM »
would: http://nl.mouser.com/ProductDetail/Vishay-Dale/RN55D7002FB14/?qs=sGAEpiMZZMtlubZbdhIBIG%2fV%2fEKkMl5tem%252b4rZG6Gpw%3d
that one do for R10 in terms of 1/8w wattage?
I don't know. I think it's too less. I haven't try.
Maybe bernbrue can confirm this.
RATMNL
« Reply #17 on: August 27, 2012, 04:21:34 PM »
that's what i thought...
what power rating do you advice in general?
EDIT: and for the power dissipation for the zener diodes.
« Last Edit: August 27, 2012, 04:39:29 PM by RATMNL »
drask
« Reply #18 on: August 27, 2012, 05:08:01 PM »
Use 1/4 watt except  for R22 and R27.
For zener use 1,3w
bernbrue
« Reply #19 on: August 27, 2012, 05:08:58 PM »
R10 is part of the voltage divider (470K+470K+ 50-70K). Take any 1/4 watt resitor that sums up to about 1M. Zeners are INI 4007. INI 4003 will do as well. General power rating for resistors is 1/4 watt or higher, 2W resistors as named in the HT section.
regards
Bernd
Last post April 29, 2020, 05:19:48 AM
by ruffrecords
Last post January 09, 2017, 10:32:15 AM
by kosi
Last post January 03, 2021, 05:18:02 AM
by New Soul Rebel
Last post March 21, 2018, 01:17:49 PM
