RATMNL
Ow nice, Thanks a bunch Kevin! I was about to ask a lot of basic question you just rendered unnecessary
M.
M.
RATMNL said:Ow nice, Thanks a bunch Kevin! I was about to ask a lot of basic question you just rendered unnecessary
M.
kazper said:http://www.jensen-transformers.com/an/Audio%20Transformers%20Chapter.pdf
Woot said:Hey Guys,
What would be the minimum voltage rating you would recommend for all the smaller film caps on the mainboard. 60v.... 100v???
Regards,
Matt
Ah crud, I used a 50V wima for c11. Good thing I haven't powered up yet!kazper said:From the tube data sheet it looks like 63V/100V will work fine. You will need to watch lead spacing too.
minor_glitch said:Ah crud, I used a 50V wima for c11. Good thing I haven't powered up yet!kazper said:From the tube data sheet it looks like 63V/100V will work fine. You will need to watch lead spacing too.
Excellent!bernbrue said:Leave it in there, it´ll work fine.
regards
Bernd
jandoste said:Hey Fabio,
Thanks for the update! Just a quick question... did you solder the heatsinks to the PCB?
memestudio said:I have not finished all the rube tube, but I checked the psu with a resistor load and it works. I have about 250V on the output.
Fabio
Hi Fabio,memestudio said:Hi Jan,
I have not soldered the heatsink to the pcb.
Fabio
Fabio
I've soldered/screwed both the heatsinks to the PCB, but i've used a insulation Mica on both...this means I can test it with no channels connected without blow it?drask said:Hi Fabio,memestudio said:Hi Jan,
Fabio
Fabio
Thank's for your answer.
jandoste find his problem with the pSU few day ago
But thank's to answer
Jerome
glbaudio said:I've soldered/screwed both the heatsinks to the PCB, but i've used a insulation Mica on both...this means I can test it with no channels connected without blow it?drask said:Hi Fabio,memestudio said:Hi Jan,
Fabio
Fabio
Jerome
