The Rude Tube Build / Support Thread (MAJ + PSU)
Hello,
There is a little mistake on the PSU board.
For the heaters, you need to inverse pin 2 and 3 of the LM350.
I updated the Manual Build.
Value missing are now present.
And there's a drawn for conenct correctly the LM350.
Thank's,
Jr
Manual Build MAJ => http://www.mediafire.com/view/?s95xkmf1cw72o54
Perfect, thanks.
Last stupid parts questions (I hope). C1 is 22pF on BOM, 20pF on schematic.  I'm guessing either value would be fine?  Also, would be it ok to use mica for C1 instead of film/tant or would you advise against that?
I would leave out C1 and R2, since these component build a zobel network for the original REDD47 mic transformer (1:7). You won´t need it with the 1:1 line transformer. You can add it later, if your transformer needs a zobel network. Check the data sheet for your transformer.
regards
Bernd
don´t set the psu under power before all components are soldered in and at least one main board with the tubes plugged in is connected to the psu. Voltages will be much higher when the psu is not under load. Check AC coming from the transformer. It should not exceed 250-270V. If the problem is still there, you should take a 5W 470R. Since I haven´t received any pcbs of The Rude Tube I  can only guess what´s going on. Jerome, it might be better to send me a few boards. Otherwise I can´t support builders here.
regards
Bernd
regards
Bernd
Yes I know Bernd, I sent you a mail about this.
Any kit left for the moment. But One PSU yes.
I can make a new batch. I'll post a feeler.
best,
Jr
jandoste said:
Hey Guys,
I almost finished the PSU board but R1[470R 2W] is smoking that I already changed TL783 and it's the same? do you have this problem or it's ok for you :)
Jandoste, I'll check my PSU ;)
I have not finished all the rube tube, but I checked the psu with a resistor load and it works. I have about 250V on the output.
Fabio
Hey Fabio,
Thanks for the update! Just a quick question... did you solder the heatsinks to the PCB?
Fabio
Hey Guys,
Received my boards, nice and quick thanks J!
Just wondering if someone could confirm the power trafo voltages for me, and if possible add a link for a suitable one?
Sorry for the noob question but I'm a bit confused.
Matt
Woot said:
Hey Guys,
Matt
Hi Matt,
This is a link for the power transfo :)
http://www.musikding.de/Passive-Bauteile/Transformatoren/Ringkerntrafos/Ringkerntrafo-230V-2x-12V-50W::2885.html
best,
Jerome
drask said:
Hi Matt,
best,
Jerome
really?
you need just 2x 12v?
not even looked at my boards yet. are there any more mistakes/finished builds up to now?
kepeb said:
drask said:
Hi Matt,
best,
Jerome
really?
Oh sorry wrong link. It's for another project.
The power transfo it isn't available for the moment on msikding.de
I'll for find a another from Farnell.
If you find, you need this " Transformers secondary need to be => 250v - 0,1A // 9v 2,5a // 24v - 0,5A"
Thanks guys.
I think I'm getting a little confused with how the secondaries are named.
So the "250v - 0,1A // 9v 2,5a // 24v - 0,5A" could be shown as 125-0-125, 4.5-0-4.5 and 12-0-12, with each secondary wired in series to give the final voltage?
If so my searches haven't come up with a single trafo that will do all of this. Or will we need one trafo for the main secondary voltage and heaters, and a separate one for the relay/lamp?
Thanks again.
Woot said:
Thanks guys.
Thanks again.
Yes, wired in series will be okay. Check the voltage after to be sure.
For the last option, why not. But we can a power transfo. Just need to search.
Take a look on farnell ...
The Mediafire site is a poor choice to host the files for the build. it's going to make it had to support this project more than a few weeks at a time.
As for a transformer, for a external cased power transformer you may try the Edcor XPWR055-120/240
http://www.edcorusa.com/p/649/xpwr055_120-240
If any of you have problems getting them to the EU let me know and I can help you out.
Bom listed transformer links:
Inputs:
https://www.edcorusa.com/p/148/wsm10k-10k
Outputs:
https://www.edcorusa.com/p/346/xs1100
LL5402:
UK = http://www.canford.co.uk/Products/23-134_LUNDAHL-LL5402-TRANSFORMER-Analogue-audio-PCB-line-output
World/Spain = http://www.don-audio.com/lundahl-ll5402_2
Us = http://www.kandkaudio.com/transformers.html
Kevin
