boji
To all you veteran recording engineers out there: In mixing, what's more valuable to you: having sufficient groups or having enough auxs?
The reason I ask is because I'm at a crossroads on my input card where I can build in either
6 groups and 8 auxs, or 8 groups and 6 auxes.
Since I have little experience working on big desks and multiplayer live recording scenarios, I could use your advice on what you see as serving more in utility, over time. Thank you!
Edit: I should mention this will be a 24 channel desk with options to add more later. DAW subgrouping would be used where applicable.
