bernbrue
PCB available now !!!!!
https://groupdiy.com/index.php?topic=53011.msg676707#msg676707
ERRATA:
1) pcb version 1.0 had a minor error in powering the relays, which has been corrected on all boards. The silkscreen numbering for two resistors was the other way round. This has been corrected as well.
2) The heater wiring of the 12AT7 tube as indicated in the schematic and on the pcb is wrong. I’ll describe an easy fix later.
You don’t need to do anything at all. These minor errors have been corrected already.
Update 15.12.2018: prototype works fine.. PCBs will be released!! Limited first run!!
https://youtu.be/iFMu9LjsDOM
Boards arrived!! Time to order some Parts
Mainboard and control pcb
https://docs.google.com/spreadsheets/d/12rNmf9cf7eQ6FiIfqCI5pxBC-OZ4AlS7xxHpd1B_OcY/edit?usp=sharing
PSU
https://docs.google.com/spreadsheets/d/1hXxtk70U6ZL8MWpZI4rOfSMPqCykkMMgWcT4OKrs5u4/edit?usp=sharing
ERRATA:
PSU
