Hi Bernd,
Thanks for the useful tips. This morning I started calibrating the compressor and I encountered the first problem. On test points B, C, D, E, I and J I have the same voltage on both channels between 297 and 300VDC which does not change using the VR103 and VR104 A-B trimpots. On the test points F, G, H the voltages measured are 0VDC and even here the trimpots have no effect. All the tubes do not glow up on both channels. No problem on relays and heater rails where I get 12 and 6.3VDC respectively. The tubes I used in the circuit are: RCA 6AL5, Mullard CV4024 (12AT7) and Brimar 6BQ7A (6BZ7 equivalent). Also, I checked all the components on the PCB to verify the values and their exact place on it and I viewed all the solders. No problems found. Any suggestions?
Ta
Andrea
