500/51X Series SLQ51X SSL styled 4000 EQ / Filter
Good point.. assuming it’s similar, the brown knob doesn’t have trim pots for high shelf, low shelf, or overall level. Just the mid bands and filters. I wouldn’t complain if it had overall level trim for me, I’m seeing a bit of a level bump when engaged vs bypass. That might be because balanced design was added to the circuit? Just a guess. I’m contemplating running it unbalanced on my console channel send/returns, which are unbalanced
Should the highlited pin below be shorted to the pin above it? The pin above it goes to ground (so the highlited pin is continuous to ground, too). I suspect a solder bridge between the highlited pin and the one above it inside the connector, but it's quite involved to fix it so wanted to confirm. Thank you!
Sorry for all the spam- this is my last post since I found my issue. Apparently, I scorched the board at one of the low freq gain pot through holes, causing it to short to ground. Instead of using the damaged through hole, I soldered in a jumper wire and the kit is working as expected. The biggest clue was that one of the legs of the pot was continuous to ground. Thanks everyone for your help!
Hi Kevin,
quick question purely out of interest: why did you change the original frequency range for the bands? Compared to the original SSL desk EQs and plugins, the frequency ranges of each band differ slightly, so I was wondering why :)
For example for the E242 (black)
Hi band: 1.4-14 kHz vs 1.5-16 kHz
HiMid band: 0.6-9 vs 0.6-7 kHz
LoMid band: 0.2 - 2 vs 0.150 - 2.5 kHz
Lo band identical
Hope my question makes sense und liebe Grüße aus Wien
there's easy explanation.
schematics are the same, part are the same ...but measurements show that the bands act in this ranges and not the "just printed ones from SSL" so I'm sure if you have the ssl by hand and you meausre it you will discover that the print is not fitting the function completely. so i wanted to be precise. so there's no change just the right print.
Hello, I purchased 2 kits of the SLQ51XBROWNREV B and I have a packet with
37x100nf
3x100pf
2x2,2nf
2x4,7nf
The only item in this specific package that is x3 is the Wima caps labeled "WIMA 100/250" with a 5 on the back. It looks to me like it might be for either step 18, or 68 on the BOM, since those are the only x3 capacitors... Step 18 is listed as 100nf, and step 68 is 220pf.
The issue is that when I test the "3x100pf" from the bag on my multimeter they're reading 0.46-0.48nf, not anything close to 100nf. Am I missing something, or doing something wrong here?
    805 KB
All built and at the calibration stage, but having a weird issue with the LMF.
Full boost, REW pumping out 1khz just fine, but as I adjust the band dial:
Starting at full counter clock wise position gain drops with knob position, just has I approach the 1.5 marking the gain starts to increase and continues to increase til full clockwise position on the dial (2khz mark).
In reverse, starting at 2khz gain drops until I hit 1 dot past the 1.5khz mark, then it climbs with knob position.
Any ideas what would cause this?
@Kevin any ideas? I'm stuck.
i don't know about your issue. for me it seems like a random problem that is caused by a misplaced component. so check all placements and find the problem like this.
I hate to ask this question but the embarrassment worth not screwing up the build.
I’m confused by the nf/pf/uf nomenclature.
For capacitors C10 and C11 should my wima caps read 4700?
I don’t want to confuse them with the wima caps that read .047.
Thanks in advance to the kind soul that sets me on the right path.
They are orders of magnitude, that's all.
1000 pF (picofarads) = 1 nF (nanofarad)
1000 nF (nanofarads) = 1 uF (microfarad)
Your 4700 WIMA cap sounds like it is 4700 pF = 4.7 nF = .0047 uF.
The one that reads .047 would be 47 nF = .047 uF.
hey guys,
I build two units and booth could get calibrated like I expect it.
But: One unit just make crackling and popping noises when I use it.
I checked all components with the working unit and the manual and made no mismatch.
I checked all soldering joints.
I have no clue what could be problem.
Maybe someone has an idea?
EDIT: it turns out it was a faulty THAT1646
Write your reply...
