I have good sounding cheap K67 capsule I wanna try in some mics I have made, I made a Neumann U87 i type circuit with a switch to switch on or off de emphasis Im using a real neumann transformer by the way, I have a real neumann K87 to compare with, I should mention Im only wiring these capsules in cardiod mode... comparing the capsules in the same mic I actually like the china cheap K67 without de emphasis its less bright than the neumann & maybe a little too dull with the de emphasis switched in so i plan to change capacitor value in the de emphasis circuit to fine tune the de emphasis.......Im also now thinking of trying the china capsule in Elam M49 and other tube mic circuits I have made.....
My question is instead of getting a transformer like in a U67 with its tertary feedback winding can add a similar set of components like in the the U87 ??? to a tube mic design..... I just want to tame the china capsules top alittle as its not as bright as the neumann capsule...
Big thanks Gary O.
Big thanks Gary O.
