Another great mic ruined by stupid internal EQ implementation. About 5db boost at 15k.
This mic appeared in my local adds for 50 bucks and I just had to give it a go. Measured, tested, bright - OK.
Opened, circuit measured, and it revealed this stupid eq curve by injecting signal. Found capacitor guilty of this, removed it, and now it sounds beautifully! I got about +5db output as well.
I am kind of surprised as this mic was modded before, by Scot Dorsey, whole circuit changed I believe. It got me puzzled, no one discovered that it was this simple? Otherwise I see no need for changing the circuit, works fine, clean, low thd. Beautifully sounding capsule by the way. No sign of 10k+ hype. Since c214 has the same capsule, and boost above 10k i suspect similar bull is done to it as well.
This is the cap that should be removed.
