AKG C414 Problem
Hey guys!
I took Gyraf's advice and replaced C8 as well as C9.  C8 was the problem and now the mic is working perfectly, and can go back to work :).
Thanks to everyone for their advice.  This forum is the greatest!!
Arie
Hey Folks,
My friend just received a C414-EB from eBay, and it sounds like possibly the same issue.  VERY LOW OUTPUT LEVEL.
The seller said it was working when they dispatched it, but when my friend tested it, to me it sounds like the character of the signal is not terrible, but at 5% amplitude strength - like, TINY.
(I can post sound files if that helps?)
Anyway, he sent it to the Aussie service department (with the AKG distributor in Sydney) but it sounds to me like all they suggested is that they would replace either the two circuit boards, or the capsule, to see which is faulty!
(except that they no longer have stock of either components)
What ever happened to servicing at a component level!! (?)
Should I suggest to the tech that he looks at the equivalent capacitors, as mentioned here with regards the ULS version?
MANY THANKS!
Evan
Thanks in advance for any suggestions.
i am wondering how to check the tantalums? What settings are required, and equipment? Can it be done on a multimeter or is a cap tester needed?
Also for c8 and c9 are there new old stock or equivalent exact spec capacitors available to purchase?
Thank you so much
You really can't check them in-circuit and expect correct reading
I would just replace on suspicion, and if that fixes it, it was proven to be problematic
You don't want NOS for tantalum caps, just get good-quality modern ones. Long-life if you can find such.
/Jakob E.
/Jakob E.
Thank you for your post.
I have a signal drop and also the low motorboating sound. It's intermittent and not the diaphragm as far as I can see. It sometimes oscillates and squeaks on the high frequency. There is a sound level drop that is quite noticeable. It can be rectified with a polar pattern switch.
I tried a few dabs of caig deoxit and it seemed to quieten down for a while. I haven't tried deoxit on the pad and low cut yet.
/Jakob E.
Can you use an ESR meter to check them in-circuit?
/Jakob E.
I tried a few dabs of deoxit on the polar pattern switch and it seemed to quieten down for a while. I haven't tried deoxit on the pad and low cut yet.
Hey Folks,
MANY THANKS!
Evan
This mic also contains a DC to DC converter (the board with the round transformer on it) to bias the capsule. You might want to check to see if it's doing its job.
Aside from a vocal test, when I move the polar pattern switch it cancels the buzzing and bumping sounds and seems OK again. However it sometimes sustains a 14dB drop for a while at times.
Can anyone recommend a decent multimeter that's reasonably priced, with a link to ebay in private message because I can't seem to find my one. Thank you so much!
I'm going to order a full set of caps, can anyone help with a shopping list and links to a good store in the UK?
I will look for any bad solder joints, loose wires, bulging caps, then replace the two foil caps, and keep replacing from there.
My memory might be failing me, but i was under the impression that the switches in these mics were infamous (?) for failing in time.
Also I read that the cover that cracks either side, establishes a Faraday cage field effect and if it is not connected properly, it can cause buzzing and hums. And guess what? Both my mics are cracked either side of the frame with the microphone mesh... 🤔 😳
If anything, that would DETRACT from the effectiveness of the Faraday cage that the headbasket and body form around the capsule. No idea what a/the "Faraday cage field effect" might be, though.
I will gladly dismiss that notion that was proposed on a forum post, people were discussing soldering cables to ground the capsule as well.. Maybe I missed the irony.
