btproductionsaustralia
- Joined
- Dec 29, 2008
- Messages
- 67
Great, i'll try that ASAP, thanks heaps!!
Ben
Ben
btproductionsaustralia said:Finall, a dumb Q: I have noticed that the sizing for the capacitors C9, C11 and C34 are different, even though they are meant to be the same component...at the moment I have a 47uf 63V in each of these, but C11 and C34 (particularly C 34) required a squashed fit, and I was wondering if a smaller Cap should be used? perhaps the 47uf 35V?
Kingston said:gswan,
first of all, I really have enjoyed reading your informative website. Then a question,
with the FET matching chapter we are measuring VDS and VGS (voltages). Yet in the excel sheets you have plotted Id (mA), as in current. How does this relate to the VDS?
btproductionsaustralia said:sorry I don't know what the hfe is, or how to check it?
gswan said:Assuming you have a supply of Vs volts and a drain series resistor of Rd ohms, the Drain current (Id) will be ((Vs - Vds)/Rd) Amps. That is to say, we measure the Vds value (since it is easy to do) and calculate the current through the resistor, which is the same as the current through the FET.
gswan said:btproductionsaustralia said:sorry I don't know what the hfe is, or how to check it?
There's usually a simple hfe tester on most multimeters these days. You are looking to use the highest gain devices in the GR amp stage and the lower gain devices in the input amplifier stage. It's probably not particularly important at this stage. You need to get the DC bias conditions correct first.
BTW, I assume your power supply voltages are OK.
