a2d
should I remove R18 to take the fet out of circut?
a2d said:ummmm the pot wiring is good, as the ratio board wiring ???
a2d said:if I have -9.05 V on the low side of the release pot I should have a constant voltage output on the other end of the 5 meg pot regardless of the pots positin , is this correct
if it is it sounds like a bad pot, because the voltage changes then you turn the pot
