a2d
Hey Brandon,
I don't have a stereo 1176, mine is a singe unit but thanks for the info
a2d said:Hey Brandon,
mac said:Hey guys,
I am just loving my dual rev J's. Cant track anything at the moment with out them
Brandon, one question for you. Did you go with Mikes stereo link boards? does it link everything? (Input gain, attack, release, Ratio, Slam, Output Gain)?
I have used mine for some "mastering" duties, but I have to work really hard to get both channels spot on even with the "link" mode switched in.
One other question for anyone to comment. I have noticed minor differences in the attack settings between both of my channels, which I am assuming may just be differences in the pots themselves (they are cheapies). Is there any other logical place to look in terms of matching channels? I am considering swapping out the attack pots for some nicer quality ones - (any suggestions - mouser preferred supplier).
Mac
Have you considered building a GSSL?
beaversaber said:Fixed the issues from a few posts up, and it all works great and sounds swell! the only thing now is there is very slight HF roll off that occurs as the attack knob is turned clockwise. maybe something to do with the cap on the attack knob? or something else?
beaversaber said:hmm, now I realize that the spdt on the attack pot isn't disabling GR either. so HF roll off when attack is turned CW, a slight increase in output level as release is turned CW, and GR disable switch not working.
Anyone around?
beaversaber said:Okay, so the switch is now working. I had the middle connected to 22 and the sides to blk/grn. Just misinterpreted the instructions that came with the HB kit.
I found that the degree of HF roll off is affected by what I do with the q bias. the further CW i turn it the more gets rolled off. is this normal? i will go through and re do the calibration procedure as well
gswan said:Yes, the 'AP' suffix means a tighter spec device ('A' series) and a plastic DIL package ('P').
The 'CP' suffix in the TL071 is a plastic DIL package code.
