skal1
cheers gswan,
now where is that tx thread.
skal1
skal1
gswan said:skal1 said:yeah i had another go at it and i had to change the meter i was using because it did not have a 1db ref , went through the calibration again and now the attack is working as it should be , those bf245 have a very tight working window might have to change the 1 turn pot for a multi.
Yes, the Qbias is very sensitive. If you plot the FET characteristics first it will give you an idea of where the optimum point would be and how sensistive it is. A 25 turn pot is a good idea for this adjustment.
Bear in mind that there will be some thermal dependancy in the FET adjustment, so don't calibrate it in freezing conditions and expect it to be the same on a hot day!
aclac said:I calibrated mine last winter, when humidity was dry and temperature was 3 degrees less... It must recalibrate now, because it compress all the time, when relase is somewhere left (slow). I noticed earlier when I calibrated first time, that when I blow little bit into PCB, then strong compression start and step slowly back after couples of seconds... So, don't breath inside the PCB- "room"!
ruckus328 said:Hey guys, I was hoping somebody might be able to tell me. I'm going to start building an 1176 soon, Mnat's Rev D Boards, my question of how deep of a 2U enclosure I should get? I need to order a couple 1U's for my GSSL's now but don't want to have to place another order later for the 1176, so figured I just get that enclosure now also.
Is 8" (203mm) too shallow?
The next size up is 11" (280mm), but don't want to go bigger than I have to.
ricothetroll said:I did the following measures :
On top of R18 : 23.9 V
Q2 : C = 1.58 V
B = -1.14 V (!!!)
E = 0.04 V
Q3 : C = 7.41 V
B = 1.59 V
E = 1.47 V
Q4 : C = 29.3 V
B = 7.4 V
E = 13.3 V
ricothetroll said:Well I guess you're right, at that step all I have to do is to be courageous and desolder - check - resolder that whole section ! It could be a bad solder too after all (I double checked the transistors and I always measure every resistor before soldering it the first time).
pearldrum944 said:What is it about changing the ratio that affects the GR meter's reading? ???![]()
ptmoore37 said:Quick (probably dumb) question for a Rev J board...
Checking my negative voltage rail (r85), i'm getting -12.85v on the OTHER side of r85. I'm getting -.04v on the side of the resistor that needs to be measured (as indicated on the PC board). All diodes are soldered in the correct direction and seems like no caps have been switched around.
I know it's something simple, that's why I'm asking rather than ripping up my entire PS section.
gswan said:rooster21 said:yes I have, but I would like to redo it just to be sure. Some clarification on the procedure would be nice.
Measurements:
1. GR bias wound out
2. Release fully CW
3. Attack off (GR disabled)
4. Apply a 0.775Vrms 1kHz sine wave to the input.
5. Adjust the input and output controls so that the output of each stage is not clipping
6. Measure the input and output AC voltage values
these where the instructions i followed but I would like to verify the folowing:
1. GR wound out meaning ccw (least resistance) or cw (most resistance), I'm assuming least.
4. .775Vrms, this means roughly .39Vrms on pin 2 and 3 respectively, right?
5. should the input and output be adjusted to the maximum before audible distortion?
For the gain tests you need to have the GR FET disabled, ie the Qbias trimmer set to where the FET is not conducting (most -Ve value on the FET Vgs).
Apply a signal to the input (the actual value is not important, somewhere around 100mV to 1V RMS should do). It's a balanced input so the signal goes across pins 3 and 3 of the XLR connector.
Now measure the signal value at the top of the output pot and wind the input pot up until you get a few Vrms there. Measure the input to this stage (input pot wiper) and calculate the gain. Do the same thing for the output section.
rooster21 said:Sorry it's taken me so long to reply, but I've had a really hard time trying to make sure that the GR FET is not conducting. I've taken some time to attempt to understand Vgs a little better. If I'm not mistaken, I should have the negative probe of my DMM on the gate of the FET, and the positive probe on the source, and when I change the trimmer for Qbias the result on the DMM (V ac) should change, correct? No matter what I change I get a fixed .012 Vac.
