beaversaber
- Joined
- Jul 22, 2009
- Messages
- 72
gswan said:beaversaber said:Here's my DC voltages for the transistors:
B C E
q2 1.038 1.727 0.556
q3 1.727 11.91 1.144
q4 11.91 29.71 11.32
q5 3.453 27.91 3.211
q6 16.28 27.91 28.46
q7 16.28 28.46 29.1
q8 29.71 16.29 15.69
q9 0.7 15 15.68
q10 13.66 12.9 12.9
q12 4.39 14.86 3.84
q13 14.86 29.72 14.24
q14 3.393 16.47 2.824
q15 16.46 29.72 15.9
I have not actually measured the output of each stage, but both input and output knobs seem to be working fine. I will check this next.
When I try to calibrate, I send a tone out with the unit in bypass, output at about halfway, adjust the input knob so the tone is coming back at 0.
I then attempt to turn the qbias trimmer until I see a 1db drop in level, but nothing happens
You have a problem around Q5. The voltages from here to Q8/Q9 are not right. Check the resistors. Do not bother with calibrations until you have the circuit working correctly.
I checked all the resistors in this section, replaced the 100ohm resistor (r36), and this is what i came up with:
B C E
q5 3.449 27.9 3.191
q6 16.19 27.9 28.46
q7 16.19 28.46 29.1
q8 29.72 16.19 15.58
q9 0.6 14.87 15.57
q10 13.66 12.9 12.9
q12 4.39 14.86 3.84
not much different from before, and the unit is still not compressing. passing audio just fine, input and output gain work fine, but qbias pot as no effect on the signal. I guess I'll try replacing the transistors q5,6,7,8,9 next?
