Hi all, I was hoping someone might be able to help me (a newbie) find a problem with my first build.
I used Mnats Rev J boards, with no input transformer, in a hairball case with hairball switches etc. I started stuffing the PCB without seeing the (wise) advice on only doing the power supply components first.. which was a shame! I've basically finished the entire build, but I'm not getting the correct readings on the power rails.
I'm seeing +30v as expected, but only -.04v on R85. I'm seeing -14v on the other side of R85 and the back of R86. I'm trying my best to understand the schematic well enough to diagnose (but struggling, clearly).. I'm seeing continuity from the middle wire of my AC supply all the way to R85 -10v measurement point, including C24, C25, C26 etc. CR6-10 are all oriented correctly as far as I can make out, as are C24-26. I'm guessing the problem is I have a short, but despite my best efforts I just don't understand it well enough to make the final leap. That is, the continuity I see to R85 appears to make sense to my eyes, so I can only assume I'm testing/thinking about it the wrong way?
Any help on how I should diagnose a problem like this would be much appreciated.
Everything else seems to be working fine.. it passes audio with no noise, input and output pots work as expected, and the metering works as expected in +4/+8. In GR meter mode (bearing in mind I obviously haven't calibrated yet), the needle slams to the right. Which seems odd but, with almost 0 volts to the gain reduction circuit I guess that's to be expected?
I ordered spares for most of the components, so if it turns out I've friend any transistors by accident I can easily replace them. I guess I just need to get the power supply working and go from there.
Any help with this would be most appreciated.. I'm pretty stumped!
James.
