living sounds
mnats said:There is a PDF of the overlay posted on my site. The topic of the two pad 18s is also covered in my troubleshooting FAQ.
Damn, I overlooked that. :
Echo North said:Are you referring the the circuit symbols arrow position?
Mike
JerryAnthony said:i'll ask it over here: What are the most common problems when the attack and release pots are not working?
cw=counter-clockwise - the contact where the wiper comes to rest if the shaft is turned all the way to the left when the pot is viewed from the front; wiper=the middle contact; cw=clockwise - the contact where the wiper comes to rest if the shaft is turned all the way to the right. If you have any doubt, turn the shaft all the way to the end stop and measure the resistance from the middle terminal to each of the other lugs. The one that shows the lowest resistance is the one where the wiper is closest to. It should read very close to zero ohms.
ricothetroll said:I cleaned the PCB but not the sockets themselves, and as my fets are matched well, removing the sockets is actually getting rid of another source of problems... For sure the contamination was in the sockets but I don't know how to make sure they're totally clean. Soldering seems like the most reliable solution.
As I searched for clues on the forum to solve my problems, I didn't find any mentioning the sockets, that's why I though it made sense to mention it, then other people that have the same kind of problem can also have that clue.
Fair enough. The usual alcohol and toothbrush would probably do but in stubborn cases an ultrasonic cleaner is useful.
