Le Roux said:
Passes signal, but I'm getting a hum.
The hum is controlled by the output pot.
As I turn the output up, it gets quiet until about half way, then gets really loud.
I have both XLR's grounded to chasis, and using Mogami shielded cable.
Quite a common problem it seems.
1. Check the grounding of your front panel. I have seen ungrounded front panels cause this. Even though the rest of the chassis is grounded, unless the front panel is wired to gound it may have some resistance between it and ground. A quick check with a piece of wire.
2. Check the location of your mains transformer and its associated leads. Move them around and see if it changes amplitude. Find the quietest spot. If the contruction is really packed in you may need to add a metal shield in front of the transformer.
