Spencerleehorton
Seems I had a bad solder joint on either the ratio pcb or the meter selector as compression and meter working now! When going through the setup when adjusting the attack control I don't get and difference between it being off and all the way on?
Also with release CW fully I get distortion, if I wind it back a little distortion stops?
This unit was the first unit I built and I do need to clean up the wiring and pcbs, so going to clean up first, then if have the same problems I need to go through with scope to find our where clipping is taking place.
When scope on output very clipped waveform.
Spence.
Spence.
