byoung
I hadn't checked that previously, but it seems to be fine. I'm going to double check voltages again, then post back.
UPDATE: I discovered that the connection from the board to the output had become severed on one of the two audio paths - re-attached and I am now good to go!Hello Folks,
About 15 years ago, I built the Rev J project to completion, and it's been working well since. I recently decided to replace the input transformer with the 0-12, and the output with an original B11148. I also found my value for R87 was wrong and had slowly burned up, so I replaced that. Just to confirm, the unit still sounded normal/fine with that resistor burnt.
I read many threads and Mnats website, and tried to figure out exactly what I needed to do to use these transformers, and I think I did it right. I'm using the 0-12 as a 2:1, and the B11148 as a 1:3.5 (I believe that's correct).
Here's the issue: the output seems like it's about the correct gain I was hoping for (similar to the original configuration), however the low end is completely rolled off. I'm guessing this is something simple/stupid I'm not considering, but I haven't been able to figure out what. One thought is, neither transformer is grounded to the PCB, as I'm not sure where or if I need to do that.
Any help, or steering me towards info would be very greatly appreciated.
MG
Is there somewhere an explanation how to convert the GSSL Rotary Switch to pushbuttons?
Sorry typo..... I meant the G1176 not the GSSL.I never seen that, but you are on the G1176 thread and not on them GSSL thread
maybe you have better luck over there
Marcelo, this is an english only forum (en el foro se habla inglés solamente).Buenos días a todos, ha pasado mucho tiempo desde el comienzo de este hilo, sin embargo, necesito su ayuda.
Construí el 1176 rev H, todos los voltajes están ahí, algunos cerca de 1v más o menos, pero están cerca del esquema, el OT se enrolló de acuerdo con las especificaciones requeridas, mi versión usa opamp en la entrada.
Ahora, el problema es que no hay audio, sin embargo, si hago una sonda conectada al potenciómetro de salida, hay audio allí, además de eso, la VU no se mueve, solo puedo moverla en Bypass con qbias preestablecido y cero ajustar. los unicos reemplazos fueron los fdh333, que usaban otros bf245 soldados como diodos (en un post de este foro), el pin 19 es negativo y tambien varia si giro q bias, igual que el pin7.
¿Por dónde podría empezar?
Thank you so much for the swift reply. Looking forward to getting this unit together!Yep, a 250v 6A power switch will be plenty in there...
