Hello Gachet,
i had a similar problem of no compression in my 1176. I used sockets for the bf245a's and i found that the connection was intermittent. When i soldered these parts in it works fine.
I suspect that you have either burned them when soldering them (i think these parts are quite sensitive to heat so you really need to be careful when heatsinking them....) or if you have used sockets they are intermittent. (i found my sockets a little tight and it was hard to get the transistor legs into the holes.
you mentioned that your input and output gain is ok. The circuit will behave this way without the bf245's in place so i think thats where the problem lies...
hope this helps
hope this helps
