Hi Everyone,
Well it's been almost 2 years in the making, but i finally had the time to finish my G1176s. I've got some issues with them...maybe. The first thing i checked were all the transistor EBC voltages and they seem to be within norms based on several measurement sets I've viewed here. +30 and -10 are looking good. The unit seems to calibrate properly following Jakob's procedure and the original UREI manual. The unit passes audio and compresses, and all controls seem to do what they should. The unit passes audio in bypass, with the FET in and out of the circuit. The line amp sounds good. In bypass I can get quite a clean signal through it in excess of +3dB VU.
My problem is this. The comp really crushes almost any signal at around 1-2 on the input, and even with the output at max, I can't really get anything above -5 dB VU. I thought I had made a mistake, so I went back and re-read this entire thread and found that a couple people had reported the same behaviors. Kdawg's posts seem to describe my exact situation. Is this normal? the controls don't really respond the same way as the other 1176s I have in the studio. [blue badge, rev F, rev H]
I am using Chef's board built to Jakob's specs, transformer balanced i/o with the romeo trace cut. The first thing I'm going to try is to rewire the output to 1:2 as i am currently running 2:1. This should help my output gain problem. But I'd really like it if the input control would respond like my other 1176. Right now it's really touchy and I feel I can't make adjustments with any precision as I am jockeying the input control between 0.5-2. Also, from a familiarity standpoint I'd like to be able to blindly [deafly?] set it at the good ol' 10 and 2 o'clock as a starting point. I'm just really used to being able to barely tickle the signal with compression at those setting.
I've tried about 4 different matched pairs of FETs and after calibration, the unit reacts the same. BTW, I am interfacing with equipment operating +4dBu @ 600 ohms in and out.
so to summarize:
1. Is what I've described normal?
2. Is there a way to decrease the input sensitivity [input pad, rewire input tranny?] that makes sense and will keep Q1 happy.
thanks for reading.
