4: "GR meter Trck" (tracking). Set ratio to 1:20, set Meter to bypass. Input a 1kHz, 50mV signal. Set input level to ~12'oclock. Set output level so you get 50mV at the output also (now you have unity gain). Now set the meter switch to "GR". Slowly turn up the level of your input signal (at the signal source, not with the input level control) while you monitor both input- and output levels with a voltmeter. When you reach a point where output level is half the input level, you have 6dB of gain reduction in the unit. Now set the "GR meter Trck" trimmer so the VU-meter reads -6dBVU. Remove input signal and (re)set "GR meter Zero" for a reading of 0dBVU. This calibrates the gr indication.
