Matt, my cynicism towards the gimmick split EQ is from having been, like you, involved with in-line consoles for a very long time; I don't see the MozRN advantage of this "feature". Split filters, Yes. Being able to use the hi-pass in the channel for recording and the EQ in the monitor path (this SSL introduced) is a good thing. The MCI guys (when Sony) copied this on the MXP3000.
If you need EQs in both paths, then use a grouping style console (and never sit in the control room's sweet spot).
Back to the original question, it is now apparent it's a standard 4-way SVF circuit.
My point is that if you are going to copy/rip off somebody else's intellectual property, rip off a decent one!! (Mentioned earlier).
And if you do want very wide ranging bands, then you have to think about switching cap values out/in to get a x3 function to avoid the upper frequency range compression. (And therefore get a more delicate/accurate frequency positioning).
Also, to understand the SVF tuned circuits used in the MozRN, look at BP's Net EQ; they are the same, using linear pots down to ground for the variable frequency component. If you hunt around the web, you will find a couple of parametric schematics that give the formula for the values.
BP's overall topology is different in that he has the SVFs all in parallel being steered into the 1st or 2nd pass amps for the ±, whereas the "standard" way is 4 inverting pass amps in series each with its own tuned circuit.
Also, for a good treatise on EQ series topology, not just the tuned circuits, dig out Walter Jung's book "Audio IC Op-Amp Applications" 3rd edition.
The M2500 is quite staightforward and at the time, none of the other console manufacturers were offering 4-band fully parametric for that price. And the schematic is easy to follow, it's not spread across how ever many pages, and on understanding it, (with the help of the above book) you will realise that the BP style SVF that you like (because it does not use dualRA pots) can be used instead.
The one thing that Rupert did was to have the HF first of the 4 in series, because everyone boosts top, so if you go for say, the M2500, reverse the order so it's HF, UpperM, LowerM, LF.
On the other hand, the NetEQ is so flexible it can be modified to suit most requirements; that's the whole point of it.
PC
