I'm very good at telling other people what to do. Delegation!Might be because English is not my native language, but your comment sounds to me like you're telling me how to spend my spare time. I appreciate all the insight about the EQ tho!
The preamp in the Mozart RN is actually pretty awesome! It's 66dB of clean gain with low noise, low distortion and a linear frequency response way past 20kHz. It should also be pretty easy to build, as long as you find a suitable replacement for the obsolete 2SD786 transistors (BC550C maybe?)..... also 9098 pre+eq on 500 shape (plate paint, knobs, etc.. included)
would be very good ,
and maybe it would sound better than the Mozart RN ?
let's leave the word about to the experts.
cheers
Yes, I agree. You might look at the ZTX stuff. Although they do not specify as "low noise" they are 1 or 2A devices which means large geometry transistors, which is good as low noise ones.The preamp in the Mozart RN is actually pretty awesome! It's 66dB of clean gain with low noise, low distortion and a linear frequency response way past 20kHz. It should also be pretty easy to build, as long as you find a suitable replacement for the obsolete 2SD786 transistors (BC550C maybe?).
The name will be cat-themed anyway =^x^=Yes, I agree. You might look at the ZTX stuff. Although they do not specify as "low noise" they are 1 or 2A devices which means large geometry transistors, which is good as low noise ones.
Look as well at the LM4562/LME49720. Although the 5532/5534 chips are hard to beat.
If you are going to adjust the frequency ranges, then it won't be the MozRN EQ.....................
