UPDATE: after some more careful debugging I found two small soldering mistakes and now my high-shelf version works! I'll take a closer look at the low-shelf version this week. But at least I can now rule out any manufacturing defects or layout issues.for some reason the high/low shelf part of the circuit does not seem to work on my pcb... I've tried to build a second circuit on another pcb and made sure to test every component for continuity while building. The Low shelf circuit will just pass audio without any actual equalization and the high shelf goes bonkers. I've set the repository to public and have uploaded the PDF in case someone wants to have a look: https://github.com/greyboxaudio/Purrtico-M/blob/main/Purrtico_M.pdf
Simulating the same circuits in LTspice works fine.
I have to admit that the schematic is a bit confusing. I've designed the schematic/PCB to allow for both high- and low-shelf to be built from the same PCB which is why not all components are supposed to be populated. I'll make that clearer once the design is ready for prime time. All EQ bands are based on the AMEK MZ-15-RN EQ module (schematics are in the AMEK technical documents topic here in the forum) and I've attached my simulation file.just simulated your schematic.... RV1 in middle position produces a sort of shelving boost, if i'm not wrong that should be zero gain when in the middle, when its max value is ccw it cuts in bell mode, at max value cw it produces bell boost....
varying RV3 the shelv slope is squared, with a deep resonance....with RV1 in middle position
i practice electronic just for hobby, so don't take it truth, it's what i found running your attached simulation in older post... i wanted to look at that filter response
do you have a schematic, from which you are taking inspiration?
I'm curious since i don't know that particular arrangement for filter section... i saw SVF but with a different arrangement...
https://audioxpress.com/article/audio-electronics-optimizing-variable-frequency-tone-controls
this Self Douglas article helped me to better understand how to mod a semiparametric into shelving, i'm building and studying Harrison eq at the moment.... and i wanted to switch HF section to shelv since that eq originally had only LF bell/shelv
What schemo are you referring to? AFAI can see, those in this thread are all self contained.it's very difficult to read that Mozart schemo, since eq pots and switches are on different page!
Since it's a cascaded design, there is no "interaction" apart from that resulting in cumulating responses.running your simulation, this is also difficult cause your filters section are individual so it's not possible to check their total output, and so their interaction, responses and other stuff to check....
i was following these 2 part schematic.... just to learn something new about this different SVF arrangement and its bandwidth controlWhat schemo are you referring to? AFAI can see, those in this thread are all self contained.
Any interaction here wouldbe the result of a fault or poor grounding or decoupling.
Parallel Eq's, such as Barry Porter's may interact.
This would be easier if you used the potentiometer that's easily usable from LTspice.The sim is technically complete and if you want the signal to pass through each stage sequentially you can connect the output of each stage to the input of the next stage instead. But IIRC my simulation uses a single pair of variables for all 4 simulated gain pots which you would also need to modify accordingly.
yes and no. For my own analysis workflow it was easier to just define the resistance values of the two resistors as two global variables that are referenced by all four resistor pairs. If I had used potentiometer models I would still have used a single global variable that is shared by all 4 potentiometers. In that case richiyobs would have had to reset all 4 potentiometers to independent values as well.This would be easier if you used the potentiometer that's easily usable from LTspice.
For example, you could go there https://groups.io/g/LTspice/filessearch?p=name,,,20,1,0,0&q=potentiometer
and find Baxendall with potentiometers.zip
Each one his own, but I find the potentiometer much easier to step and also closer to a traditional schemo layout.yes and no. For my own analysis workflow it was easier to just define the resistance values of the two resistors as two global variables that are referenced by all four resistor pairs. If I had used potentiometer models I would still have used a single global variable that is shared by all 4 potentiometers. In that case richiyobs would have had to reset all 4 potentiometers to independent values as well.
discrete resistors sound warmerEach one his own, but I find the potentiometer much easier to step and also closer to a traditional schemo layout.
When I se your .param statements, they are more complicated tah a potentiomter where you just adjust one parameter, without teh risk of enering values that don't match the nominal resistance.
For example, your statement ".param G1=4k7 G2=1" requires changing two values, that's two risks of mistake nad nothing will tell you that ".param G1=4k7 G2=1k" is wrong. Using the potentiometer model prevents errors due to typos or miscalculations.
I've modified your schemo with potentiometer models and .step staements, which, IMO are easire than editing resistor values.
I can step all potentiometers simulaneously if I wish.
Depends what brand/type. I prefer SFER conductive plastic in my simulations.discrete resistors sound warmer
touchéDepends what brand/type. I prefer SFER conductive plastic in my simulations.
I tried carbon comp for fixed resistors, but they drift too much.
I've now been able to fix the low shelf as wellPCBs have arrived and I've at least got the parametric mid band correctThe shelving filter still needs some de-bugging because I've accidentally wired a potentiometer incorrectly. To keep the BoM a bit more flexible I've assigned simple pin headers as footprints for the potentiometers. However this "Hack" does not work for dual potentiometers because KiCad uses a different numbering scheme for double row pin headers and I forgot to manually edit the footprint of RV4
