Howdee,
Could anyone direct me to a pic that shows where the points are for the plate on the first stage of the tube and the ground are ? I wish to solder in a 200 pF styrene capacitor to roll off a bit of the high end.
Thanks but i am hoping there may be pics of soldering positions on the pcb or even a pic showing the capacitor in place from someone that thas done the mod.
the plate on the first stage of the tube + the ground
Oh ! I just place the capacitor between 2 pins on the tube socket to create the LPF ?
Errr, I suppose so. I just assumed it would be connecting 2 spots on a PCB like this (but instead, the equivalent spots on the 460's PCB) :
Thanks !
Is Pin 1 the plate of the 1st stage and Pin 7 the plate of the 2nd stage ?
https://groupdiy.com/threads/apex-460-noise.53875/ (Apex 460 schematic)
https://www.amplifiedparts.com/tech-articles/12ax7-tube-diagram (12A_7 tube pinout)
Google is your friend
I can see Pin 9 is called “base” so i assume that’s the ground.
How about pin 1 or 7, and pin 9 respectively?
I think i am looking in the correct section : Pin 6 = PT1 and Pin 1 = PT2
Pin 7 = GT1 and Pin 9 = HM
