samgraysound
JohnRoberts said:Sorry I use spice(s) only when cooking in the kitchen...
We have a logical paradox... You tell me you measure 65V RMS across the transformer, but do not get the expected as much as 90V peak driving the gate circuit.
It could be something obscure like the transformer CT J1 is not the same 0V "ground" as as the JFET source 0V ground.
This is physics not magic so the answer is something simple and logical, while it will seem a lot more logical after you find it.
Probably a bad connection somewhere, as I suggested earlier confirm the integrity of associated connections (like transformer CT).
It's always something.
New day! I calibrated my oscilliscope quickly with my DC bench supply. On the scope the secondary voltage is approx 85vac p2p. The wave at the junction of D3 and D4 is little less then 40.
I breadboarded the circuit with all new components and hooked it up to the transformer. Everything acts exactly the same as on the pcb.
I tested connection between the transformer ends and ct, those are there. I measured voltage from each end to ct. 32vac RMS.
I emailed Ashdown and asked for the V+ and V- voltages. They said they should be +/-80v. I have +42.5 and -48.5. The preamp board is supposed to have +/-15 and it is low as well. So new theory, it's the PT. I emailed Ashdown and asked for secondary voltages so I can confirm.
