Newmarket
Higher voltage rating is not a problem. All other things being equal cap life is extended.
Yeah, you're fine with a 50v and the larger resistor.hello everyone,
On schematic we have 10uF/35v capacitor but I would like to use a 10uF/50v. Upper voltage is not a problem in this module? the same I have problem to with resistor, can I use a 0,4W?
Your 200v resistors are fine.I ordered VISHAY resistors metal film, 0,4W 1%, dimensions 1,6x3,5mm max voltage 200V. This resistors is really small. Not will be problem? I read severals page ago post that resistors must have around 400V. Can I use this? of course I can replace to 0,6W 350V
For some reason when someone posted a public Mouser BOM for this build, all of the resistors were WAY bigger (voltage and size) than they needed to be. I built my first two using this BOM. Then I fixed the BOM and posted a link here somewhere, probably 2 years ago.I ordered VISHAY resistors metal film, 0,4W 1%, dimensions 1,6x3,5mm max voltage 200V. This resistors is really small. Not will be problem? I read severals page ago post that resistors must have around 400V. Can I use this? of course I can replace to 0,6W 350V
Can you direct me to the name of (or link) to these connector pins, please? Both ends.
I know they aren't necessary but I'd like to use them for my build. It would also be awesome if they were included in the BOM!
I think you and I might have the record for Bo Hansen DI builds!Hello, Everyone,
I've built a myriad of these DIs with various transformers for myself and for others
Be sure to get the gold or selective gold versions. The tin is not that good for low voltages. The Molex crimp tool is 638112200. Use the "B" slot.Look like Molex KK type with Friction Lock. 2.54mm or possibly 2mm "Hard Metric". I've used/specified a ton of these professionally and for my own DIY stuff. They are really good. Small enough but not too small to allow easy removal of crimp when you get a connection wrong . But you do need to use a proper crimp tool and a bit of practice for reliability. So don't use a long nose pliers then blame the connector system
Note that there are two different crimp sizes for different wire gauge ranges.
You can look up the details on the Molex site or via RS / Farnell / Newark etc.
