Hello, glad to see you guys!
it’s first time to post the Group. I’m Korean, my main hobby is building guitar stompboxes and tube amps.
I built Bo’s DI with Vigortronix VTX-101-003.
Original plan was OEP A262A3E, but it was out of stock.. so I chose it as an alternative.
Both have exactly the same spec, but I can hardly find reviews.. (I found only negative one) so there was a bit of doubt
FYI the Vigortronix one is even cheaper.
and finally, I made it.
with 1590A !
It was hard to place the XLR jack, the mounting screw almost touched bottom plate screw.. however no problem after all.
I wired the circuit around input jack. As you expect the space is very very limited..
True to its reputation, the sound of this unit was undeniably excellent.
Low noise / High definition / Wide range dynamics..
At this point, the performance of Lundhal is highly expected. I’ll try it someday..
Thank you, Bo. Thank you.
