perhaps using a conductive plastic pot instead of carbon? But theres a reason why that would happen to a carbon pot which I havent run into on either of mine.... hmmm
thesystem said:Hi guys, I'm wiring my 1176 right now and everything is going well. I'm about to wire the T attenuator to the input tx but I want to use an original UTC 012 which I bought on ebay. How do I connect the wires?? And is there also a nice way to mount the 012 to the chassis cause it doesn't fit the hairball pcb. thanks!
thesystem said:Thanks Mark, a capacitor ring might work.
I'm not that good in reading a schematic so please tell me if this is correct:
- positive output of the T att goes to 1 on the 0-12
- negative output of the T att goes to 5 on the 0-12
- 6 on 0-12 goes to input on PCB
- 8 on 0-12 goes to earth on the PCB
- Do I still need to add two 620 ohm resistors on the bottom of the T att PCB or isn't this needed anymore?
college101 said:Thanks to everyone on here who has helped me in the past..I plan to help anyone I can...and if you want to message me, feel free to do so...
sr1200 said:Gaaaaaahhh!!! found the prob! the wire going to pad 22 was reversed on the attack switch! DOH! works fine now....
acoustix said:Hi,
I have a question about my futur RevD board.
In mouser 2N5457 are obsolete.
In stock there are only 2N5457_D26Z and 2N5457_D74Z.
I can see no difference between this part, and data sheet is the same.
Is this parts are good ?
sr1200 said:![]()
see the thick black wire thats connected to the back of the switch part of the attack pot? I had the lead (insulated wire) going to the pin on the left, and the shielding on the right (backwards) once I flipped that around.... "Aaaaaaaa"(angels singing)
