looks good to me, just check that they are going into the right holes on the board (or terminals if youre using them).
Nobody knows difference between 2N5457, 2N5457_D26Z and 2N5457_D74Z. ?? :-\acoustix said:Hi,
I have a question about my futur RevD board.
In mouser 2N5457 are obsolete.
In stock there are only 2N5457_D26Z and 2N5457_D74Z.
I can see no difference between this part, and data sheet is the same.
Is this parts are good ?
college101 said:did you check HFE on all the transistors before soldering them?
I will !! thankscollege101 said:Did you check the gain of the transistors? You have to measure this on a multimeter....
You have to match the gain levels so they function together...If one does not work, then it could be causing the problem
For example...all of my q7- q10 transistors measured 368-370-371-370 hfe
college101 said:Germoju...I found it easier to just re-do my board..but another one,buy the new parts again, and try it over...Sounds like there is a couple things you missed on your first try
I had the same problems...I let the rookie excitement overtake me, and that was what casued my errors...for real mate...Take your time, and go slow...
Install your parts in this order....resistors,diodes,Votage regulator, capacitors ,transistors, pots
Go in that order, and you should be fine...double check your measurements, and then write them down as you take them, then install and solder one part at a time...you will get it right!
??acoustix said:Hi,
germoju said:??acoustix said:Hi,
Echo North said:germoju said:??acoustix said:Hi,
Those parts have "kinked leads" so the footprint is wider. They could probably made to fit. I have enough 5457's to last a long long time so they'll be available for future builds.
turn the release pot around, so it follows the guide pictures from mnats site,...when stuff is backwards or inverted, your going to cause more errors...you need to follow/copy the pictures if your not going off of the schematic
Hope I can help
Just got mine working, and its the bomb
Echo North said:Just to clarify, make sure you are not confusing 'GRN" with "ground". In the UREI schematic "GRN" means green. "BLK" means black and it's the black that is connected to ground. So in the off position 22 is connected to BLK and in the on position 22 is connected to GRN.
