no R4 is 270. not 270kpittsburgh said:Is R4 supposed to be a 270K Resistor? It's labeled on the PCB and sheet as a 270R, but under the description it says 1/4W resistor.
I have a 270K resistor here and don't see another place for it to go, just want to make sure before I solder it in place.
-P
did i see you zeroing the meter with the front panel adjustment? YESsr1200 said:yeah, step 1 should have the jumper IN, also... did i see you zeroing the meter with the front panel adjustment? 44 is for the tracking adjust, and 71 is for the 0 adjust (right?)
Echo North said:Did you test the output to see if it's compressing like I'd suggested?
Do it with your DAW. Look at the output in your DAW to see if it's compressing. We need to confirm that a) the unit is compressing and it's a meter circuit issue or b) the meter is right and it's not compressing.Echo North said:Do it with your DAW. Look at the output in your DAW to see if it's compressing. We need to confirm that a) the unit is compressing and it's a meter circuit issue or b) the meter is right and it's not compressing.
Also did you do the pad 22 blk/grn continuity tests I mentioned earlier. We need to confirm your side chain isn't shorted to ground.
pittsburgh said:I'm looking for R63 on the ratio board. R63 is a 1.5K resistor. Is it supposed to fit in R6 on the ratio board? Do the numbers on the right hand side correspond to pad levels?
sr1200 said:yeah, i was starting to take it personally. lol
