Great to hear your unit is working : )germoju said:sr1200, my hero !
thank you so much ! MY 1176 WORKS !
after some hours testing everything, sr1200 make me test the ratio board : BINGO !
I had a problem on the ratio board between pin4 and middle of the switchs :
molex_header_ratio_board2 par volcanovap, sur Flickr
not connected... I add some soldier but nothing change... so sr1200 told me to make a bridge between pin4 and pin on a middle of the 20.1 switch. Now they're connectedSo we finished the calibration and compression was born !
;D
I'll show you with a picture tomorrow. (better than my english...)
for sure, now I got one 1176LN and one PCB alone. I have to re-order hairball-audio
THANKS YOU EVERYBODY FOR YOUR HELP![]()
canidoit said:Just curious, what was wrong in the end? Was it the PCB board, bad switch, bad connector or bad solder that caused this particular issue that you had to jump it? Maybe someone else might find the cause useful when they are troubleshooting.
pittsburgh said:I'm coming to the conclusion that resistors for the ratio PCB board are not a part of the Mouser parts list. Is that right?
sr1200 said:Thats perfectly normal, you should hear the tone you're putting into the unit.
Stagefright13 said:germoju the orange and yellow wires on the output transformer need to be soldered together.
John
germoju said:Stagefright13 said:germoju the orange and yellow wires on the output transformer need to be soldered together.
John
thanks... I did not solder them. The contact must be bad. I will fix this ! Thanks !![]()
pittsburgh said:So just to clarify, if I'm using the push button system for the ratio, I need to use the hairball PCB and disregard the MNATS ratio/meter board?
germoju said:germoju said:Stagefright13 said:germoju the orange and yellow wires on the output transformer need to be soldered together.
John
arrrrfff... I think I got a new problem... I re-soldered the orange and yellow wires together on the output transformer. Nothing changed ! I got a real big low-cut maybe at 300 hz![]()
