Echo North
wkbdgeorge said:ph- good to hear someone else is running into this. My units are the pushbutton and not the rotary. Can anyone else confirm that moving up in amperage is an ok thing? Is the heart of the problem coming from a switch issue?
Just to check, Im switching just one side of the iec supply. So the neutral wires of the transformer go directly to the neutral iec, then the high gets fused, then to the switch, then to the transformer. Is this right?
Is anyone else blowing fuses with the hairball push switches?
I have blown a few 250mA slow-blow's but it's very rare for me. Maybe the rotary is taming the inrush current a little but I can't see how. I've measured inrush to be over 500mA on 1176's. You could move up a little on the fuse like pH. I wouldn't go above 500mA slow-blow.
