ask
That's good
Rob Flinn said:...I wouldn't terminate the unused side of a power amp !!
The 1:1 transformers and the level pot before the 47K buss resistors would be a fine idea. Check out this link for something similar. For multiple outputs, I have the boards set up with a 2nd output already via a simple mult. You could easily add a 3rd if you wanted with no real change.mylesgm said:So Thinking about building a stand alone simple line summing box. Like the idea of doing api way and I'm wondering about balanced inouts prior to the 47k resistors. So I've got a pile of astor/awa 1:1 line transformers and was going to do 16 inputs via transformers then on to the 47k resistors and the rest of the circuit. Will this be suitable and could I add a pot before the 47k for attentuation? Also, how could I add multiple outs to the master out? I would like to return 2 channels to the daw and a 2 channel split to go to the studio monitor selector.
thoughts?
Hmmm... you would expect the high to be a little more level
s the API plot of both stages or just the first ACA stage?
I remember you modified the feedback R and C to match with your buss R's??
Ryan, to answer the above would be a text book worth of data! That is more about "input channels" than the ACA part of the console. This build is more about what comes after the input channel, the ACA. I would recommend many searches here and also picking up the book "The Handbook for Sound Engineers". I also remember John Roberts posting a link here to a rather large and great article he had written on console design and architecture. This will also be helpful.RyanC said:Hi Jeff-
So I'm looking to price this out for a larger matrix mixer, what would be the pot/fader values (pan and level)? And are there any specific parts you would recommend? I'm looking at a 34x20 matrix mixer, with stereo buss assign, pan and level (probably on a pot to save space) on each mono input. Does panning require extra buffer circuitry, or just a linear pot?
Yes the ACA output is transformer balanced with 2623-4's. The polarity is properly inverted with the primaries of the 2623-4. The booster or 325 part of the circuit is not 100% necessary.Also, on the matrix mixer, I wont need a meter or an insert point (would just insert post mixer) so is the 325 half necessary if the -2dB level is not a problem for me? The output of the ACA half of the card is balanced right?
Hi Pedro,PATAPETER said:Dear jeff: I'm new in this forum . I want to tell you that I love What you are doing at classicAPI. I have an API 2488 from 1972 ,If you need any schematics just ask for it, With 528 modules and 550 A eq's . And my question is , my console doesn't have any cards like your's ( 312 or 325 ), I want to know if the summing stage is like yours with almost a 325 cards after de st fader , Because i see the st and busses aca , but dont see the oder stage.
I'm trying to built a mini console with a replica of the 528 modules without the cue sends and aux send,only the line/mic and the 1 and 2 buttons for the low filters , and the pan and st / busses assign . Then I will need you ACA bo cards and transformes , i already have scott's sl 2520 vintage and some vintage 2520 originals.
Best Regards
Pedro Pearson.
Pedro, are you sure about this? My input channels have 2623-1's on them. I don't see how 2503's would fit on the boards. They would not fit between the DPDT Schadow switches and the channel peak circuit. I have 2 544 channels here from a friend's 1604. One module has a single 2623-1 (no direct out) and the other channel has 2 of the 2157's. They are also the smaller transformers with 2 secondaries. I would not be surprised if maybe your modules were custom? I know API did a lot of custom work back then. Almost all of their consoles were different in some way or another.PATAPETER said:...the 2503 are inside the 528 modules 2 of them...
No, on this one I don't. It will take a bigger man than me to tackle the 500a. I think maybe Peter Purpose could do it for sure. :-*Do you have any ideas on cloning the 550A EQ ?...
