Echo North
ebenchristensen said:Getting
0.032 VAC
Q1 is still removed (per your recommendation ) btw
Do you have all 3 L-Brackets installed on the back panel? Fully screwed in, tightened?
Mike
0.032 VAC
Hairball Audio said:Try this:
Input/output: Mid Way
release/attack: full CW
Ratio: 20
Meter: GR
Feed and confirm a 0.775VAC 1K signal measuring between input XLR + and -.
No measure these TPs using chassis as your common.
TP22 - Measure for AC for all ratios and list them.
TP21 - Measure for DC for all ratios and list them.
Mike
Hairball Audio said:@mixmasta
#1 Does adjusting the Qbias to either extreme change the output?
#2 Contact with the gate at Q1/11 just sends the unit into extreme gain reduction. Have you tried calibrating it yet? Make sure all of the L-Brackets are secured on both units. One of them ties the PCB ground to the chassis ground and is needed for proper operation.
R17 value is not the issue. The new value is correct.
Mike
Hairball Audio said:For the low output unit, I would start by going over all of your resistors and visually checking the values.
Looks for anything out of place in comparison to the working unit. Look for any suspect solder joints.
Mike
If power supply voltages were correct before populating the rest of the board then something must be dragging the -10 v supply down. Set your multimeter to measure resistance and measure between the anode of CR9 and ground. Remove CN3 and try again to see if your ratio circuit is causing an issue.CBarx said:Strangely enough, even though I tested the power supply voltages of all PCBs before populating the rest of the components (All voltages checked out fine THEN), I'm now seeing that the left lead of CR9 is giving me a reading of -1.5mVDC. The 30VDC test point check out fine. I'm at a loss here. I've gone over components and can't find any mistakes, and I populated all 6 boards at the same time, so if there was an issue with one, there'd be an issue with all of them. Any help here would be greatly appreciated.
mixmasta said:I compared all the resistors and the color codes are the same. Also had a look at the bottom side and it does look clean, no shorts or forgotten solder pads that I noticed. Did touch up a couple of solder joints but it did not make a difference in the levels coming through the unit. Also checked the transistors and small film caps to make sure I didn't mix up something there.
I got 0.775VAC at the input but don't know what the values should be later on as I haven't fully figured out the schematic yet. But I compared some points that I could identify being in the audio path between the 2 units, and levels seem to be down throughout the unit.
With input/output at 24, 20:1 and GR off, on the functioning unit #2 one I got:
TP15: 3.746 VAC
TP17: 0.6 VAC
at R8: 0.087 VAC
at R5: 0.086 VAC
The values for #1 were:
TP15: 0.5 VAC
TP17: 0.15 VAC
R8: 0.012 VAC
R5: 0.011 VAC
Hairball Audio said:The low voltage at TP15 indicates something is bad in the first gain section. Does removing the Q1 FET help get voltage at 15?
Hairball Audio said:@RR25
Your TP22 is real low. What is your V AC at pad 15 under the same conditions?
Mike
RR25 said:Hi Mike, I have tested TP15 and I got a reading of 0.072V AC (0.775V AC at input test points, referencing the chassis, Input and output = mid, 20:1, meter = GR, attack and release = CW)
Thanks for the help Mike,
mixmasta said:Yes, when I take it out I get +3.9VAC at TP15 and +18dBu at the output. Does that indicate a bad Q1 or something else in that gain stage?
Hairball Audio said:It indicates a bad FET or bad qbias circuit.
With the FET out, what is your DC at the GATE pad of Q1 as you rotate the qbias from end to end.
Mike
mixmasta said:I have 0VDC at the gate of Q1 for the whole trim range, it must be the Q Bias circuit then.
As mentioned in my earlier reply regarding your issue, Mike's analysis agrees with mine. If you are building an "A" then your transistor voltages are wrong; check all components in that stage for value, soldering, shorts etc.Hairball Audio said:This is with GR bypassed? You have something wrong in your first stage labeled "signal preamp".
Mike
ccommon said:Hey Mike ,
I Finished the Build on my second REV A , and things seem to go smooth untill i tried to CAL it.
The R59 Q Bias would not Drop the 1 db or down to 2.44V on the , but the meter on the REV A would drop all the way down as I adjusted.
I check around and looked for anyhing out of place or any cold solders , But all seemed fine . The last thing I check was the sound of the output . With a 1K tone @ 0 db Passing through , the output of the unit was distorted even with the output pot all the way down.
what could I have messed up this time haha .
let me know if you need more info
thanks for the support
-Chris
