[BUILD] New FET/RACK Official Help Thread - Please read first post!
controlvoltage said:
Ah, yeah the tolerance could be the reason. I haven't tried measuring the pots, actually. It's not really a big deal, honestly, as I use the very nice metering on my Dangerous AD+ Converter to match if I need to. Though I do actually have a bit of OCD, it's not so much this kind of thing that bothers me unbearably.
Why would it be that a test tone wouldn't work well with these, though? I'm not sure I follow that.
Not sure why that is with a test tone either, but I had a similar conversation with Mike regarding this a while back. I just know that if I use tone to match stereo linked FET Rack units I wind up going back and readjusting when putting something like a drum mix through them, and the positioning of the knobs end up being more closely matched when the program material is balanced.
Paul
So, I have a question.
I've built two FET Rack Rev D units and they were ordered not too long apart from each other, though not at the same time.
They both sound great and work correctly as far as I can tell. However, it seems like the taper on the output control is quite different between the two units. I have them set up so that 24 is exactly the same on both units, however if I were to set one to 18, the other would have to be set significantly higher to match the same output. If I go the opposite direction they also don't line up anymore.
Was there a taper change at some point?
The inputs seem to be a lot more closely matched, though I do have to tweak just a little to get exactly the same gain reduction with the same 1k test signal.
The pots have a 20% tolerance (industry standard) and for a single deck 250K pot that can amount to a pretty noticeable difference.  About a year ago we started matching them on stereo units. It's impossible to do that when units are ship separately.  If you want to email us, we can have you measure on of your pots and we can get a matched one for you.
Mike
Paul
With a pure sine in the stereo set-up, these seems to be a bit of a phase shift issue that makes them hard to get in stereo.  With actual recorded material it's totally fine.
Mike
Not sure if there is an answer short enough to give on this here without "read more books, study more," but I have 4 Hairball kits waiting to be unboxed and sort of want to understand more about the circuits before getting into the builds. In particular I'm stumped on what should probably be the most basic thing: identifying the coupling between stages....
Todd Sharp the guitar amp guru (my hero) here in Nashville where I live gave me a short stack of book recommendations last fall and I've been reading old tube/amateur radio texts for the better part of the past year (since after my Lola & Rev.  A initiation into DIY) but realize the 1176 circuit has more going on than I'll be able to fully grasp at first. Just want to get the big stuff....
In the tube stuff I've been reading it has driven home that coupling networks are for  connecting the output of one stage to the input of another and with RC coupling there's been a capacitor across the plate circuit.
When it comes to transistors (at least BJT's), my initial efforts at understanding have understood the base to be analogous to the cathode, emitter analogous to grid, and collector analogous to plate, so the collector would be the output unless I'm totally lost in space (and may be at any moment in time).
So on the Rev. D, I understand from the Orange Drop mod/sales page that C1, C7, C8 and C10 are the coupling capacitors, but when I look at the schematic I'm failing to see the connection from C7 to  collector ---- I see  it to the emitter of Q14, but am not seeing a connection to the V+ line (coupling caps involve low reactance to AC but blocking DC right?? Again, unless I'm lost in outer space), or the collector of anything.  Sort of the same dilemma with C8.
C10 actually makes sense. I can see that connected to collector and also the connection to V+. Last, C1 I can see the connection to Drain of the FET but am confused by where V+ goes on the schematic. I see it connecting to the collector of Q2 but am not tracing it back to Q1 the FET.
I may simply be in over my head so if there's not a short/simple answer to these questions would you have any recommendations for transistor based texts along the lines of the '50s/'60s tube books I've been reading???
Sean
I think the UA 1176 manual has a decent theory of operation section that may help with some questions regarding it if you haven't already read it....... maybe not.....
Interesting question. I'd like to hear more on this as well .....Surely there are some threads around here that discuss good resources??? IDK though......
edit....just saw this.....
https://groupdiy.com/index.php?topic=6329.0
I just Googled transistor theory groupdiy.....Sometimes I have a hard time locating stuff using the dedicated search here and searching google with groupdiy included usually helps......
good luck!
Thanks. I just got to the 1176 manual from mnats' website (where he links it). I'll go ahead and have a read through the Theory Of Operation chapter.
Mike, if you have any advice on this (even really simple "read this or that book" kind of advice), I'd be forever grateful!!! Look forward to getting into the builds which I ordered last summer (I'm a little slow). I moved across town and have been unpacking boxes for the past 3 months straight but this spring I'll get started on another Lola and three more FET/Racks (all waiting in the shipping boxes temporarily stored in my guest room!). After the past 15 or 16 months it's become very clear I'm not doing any of this as a way to get better gear for cheaper, but that ultimately, I sincerely want to learn more than where and how to solder. It's become a mission (at 36; I feel so old to be starting)
good luck!
Scanned your post, sorry short on time.  Sounds like you're assuming all of the transistor stages are common emitter stages, which are indeed the most common. However Q14 is set up as a common collector with the signal on the emitter.  This is most likely used to get a low impedance before the next stage. It has no gain.
C8 is on the wiper of the output pot to block DC before the signal inters the final line amp stage.
Input pot controls the level/volume to the signal amp (and GR amp) and the output pot is the level volume setter for the line amp stage.
Douglas Self has a great book called "Small Signal Audio Design".
Mike
Hey there, I've been going over my Blue stripe release issue for a while still. To refresh really quick, the release control doesn't respond. It releases just as fast on the slowest setting, as the fastest setting and  I cant seem to find an incorrect component anywhere. I went over all my solder joints and re did a few that looked suspect but no luck. I should mention that the matched pair of 2N3707 transistors for q12 and q13  didn't come taped together.  If I didn't install the correct matched pair at Q12 and Q13, would this cause my issue?
Thank you for this, Mike. I got the book from my alma mater library. It's a little over my head right from the top. Haven't yet learned much about solid state circuits or op-amps so as soon as it gets into open-loop gain and negative feedback in the first few pages of Chapter 1 I'm lost, but I will certainly use this as a resource as I learn enough to be ready for the text!!! I appreciate your time as always & will check back in once I ever get started on the three 1176 kits I bought 9 months ago!!!
Mike
No that wouldn't be your issue.
You could try removing and testing you release pot...or maybe you have a small solder bridge in the release pot feet.
Also too much flux around Q1 can cause that.
Mike
Mike thanks for the reply.
I built the attack/ release PCB from my second kit to try that out and I’m still having the same problem. No visible solder bridges and the area/ joint at Q1 appears to be clean.
Weird..sounds like you're sending it in for repair...we'll get it working.
Hey guys, I just finished my first Hairball Rev. A build and the 1st. calibration step (Q Bias)  checked out fine.  But on the 2nd step (Discrete Meter Circuit/Null Adjust) I get no movement at all from the VU meter when setting the zero adjust pot. I'm a novice at this stuff and have gone over all my solder joints and double checked that all components are in the right places. Any thoughts on what could be going on here would be greatly appreciated.
Mike
Mike
Does your meter work in +4/+8 with a decent signal through it?
Mike
Not at +8?
That's super weird...how do you feel about your soldering skills?
I feel pretty good about my soldering, I used the recommended solder and tip and watched Dave Jones' tutorial. I have successfully built a tube opto compressor and I double checked all my joints under a light and magnifying glass. Any Ideas where I should triple check?
I'd start by making sure the white plastic headers on that meter PCB and their counterparts are soldered to the board in the right orientation and not rotated 180 degrees.
Check all of your components value and placement in the meter section and the meter PCB.
Test the meter switch +GR switch with an ohm meter.
Report back!
Mike
Thanks Mike, you were right the first time, I had one bad solder joint on the meter board. Everything is working now except for the 10db drop adjustment. Can't get it anywhere near the right range. I made the mistake of mixing my Q12 and Q13 transistors with the others so they may not be matched. Could that be the issue?
Could be.  However I would start here:
https://www.hairballaudio.com/blog/resources/post/fetrack-troubleshooting-guide
Check steps 2-5.  Your voltages may be a little different because we switched t-pads, but they should be in the ball park.
Post your findings.
