Echo North
sonority7 said:Would this be affecting the sound quality? I have nothing to compare it to so If it's just a low output I can deal with it. It seems to be working fine but I want it to be the best it can be and will send it in if you think it needs to be looked at.
It's just impossible to troubleshoot on the forum if values are changing, in this case pad 15. It's either a bad connection or you're overlooking something in the setup/measurement. Since it sounds like the unit still sounds good and the same as before, I suspect you might just be overlooking something in your set-up...which is super common since there are so many little details.
If you can, see if you're getting about 40dB of gain from the unit. I don't know you're set-up, so you'll have to figure it out, but basically you want a -40dBu input and in GR OFF with both in/out maxed you should have about 40dB of gain. However, if you're new to this stuff it can be a little tricky.
Mike
