radiance
rrs said:have disconected LM7812 and no short between 2 and 3.
You mean, no short between pins 2 and 3 from the LM7812 right?
Did you check if there was a short on the board as well? It seems there must be a short on the board right?
Also, I see your diode's are mounted tightly on your board. Did you put steel clamps on them when soldering them? To release some heat while soldering?
Maybe you've a faulty diode. They can't handle much heat.
I always mount them 5 to 10mm off the board so there's enough space for a steel clip while soldering them....
